My new Tq monster 383
Old May 28, 2011 | 07:11 PM
Marv02's Avatar
Car: 1986 Vett, 2001 Expedition
Engine: 383SBC 435 H/P, 500 TQ
Axle/Gears: 307
Well my 357 it toast.
So I bulding a new 383 for my 86 vett
It a 4 bolt main 1 piece Main seal Eagle Rotating assmebly .040 over flat top pistons it should be 10.5 to 1 with .038 heads gasket and 195 Trick flow heads 62cc 202 intke vavle 160 Exhaust valve.
Luntia 60101 Cam .213/.218 duration, 486/494 lift, 112 CL, 108 intake CL.
24# FIC injectors SPL runners Edenbrock High Flo Intake Base, SPL full lenght headers, Magna flow cat back 307 Rear end, 8 Qt oil pan, Through a 700r4 trans 2500 Stall.
On paper it should make 499 TQ @ 2000 thru 2500 RPM 380 H/P at 5000 I wanted a fun street car that can driven every day.
Old May 29, 2011 | 01:42 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: My new Tq monster 383
I'm wondering if 24's will be big enough. Also, 1.6 rockers will help as that duration/center line is good for torque but more lift, (within reason), never hurts.
Old May 29, 2011 | 07:48 PM
Marv02's Avatar
Axle/Gears: 307
I using 1.6 CC Ultra Magnum Steel full Roller rocker arms.
I looked around and 24# should work fine I t not a 7000 RPM motor so I should not need that high of a fuel flow for 5500 RPM motor.
If not I be buying anouther set of injectors LOL.
Old May 29, 2011 | 09:29 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
why that small of a cam with a 383 and 195 heads?
Old May 29, 2011 | 09:36 PM
Marv02's Avatar
Axle/Gears: 307
I pluged the numbers im for the next larger cam 60102 it makes less power with the same motor set up I dont need a 7000 RPM screamer a 5500 max every now and then type motor.
I have to pass Ca smog with it.
And what I read I do you dont have to use a aftermarket I alreay have a chip from the last can should work they say the cam I goning to use can work with the stock tune also.
Until I get a custom made chip.
Besides gives me some more time to see if the 24# injectors will be enough.
Old Mar 14, 2012 | 10:05 PM
Copperhead's Avatar
Where do you find a HP/TQ calculator like this?
Old Mar 15, 2012 | 07:14 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
http://www.proracingsim.com/desktopdyno.htm
http://www.virtualengine2000.com/
http://www.motionsoftware.com/
Be aware, the non pro versions of these simulators are only good for comparison between different combos;
real world results may vary from predictions
Some are too scared to put their engines on a real dyno to find out what it actually makes ;
preferring to claim the " estimated " results
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
