Iroc-z Dies while driving on the Highway(HELP)
Old Jul 18, 2011 | 04:39 AM
Iroc87Stud's Avatar
I have a 1987 Camaro iroc with a 350 5speed with around 63K on the motor...if i drive around town to the store or friends house it drives perfect but as soon as i get on the highway and go abt 20miles down the Highway the car always dies out of no where but will start right back up 30 to 1hour later and drive fine again untill i get back on the highway...the battery is new along with starter..first it starts chuggin and shakin and then dies..it just cranks over like it ran out of gas...thinkin that the fuel pump gets to hot and cuts off untill it cools down...
?????????????....what do ya think....
Old Jul 18, 2011 | 05:41 AM
gbayfisher's Avatar
Car: 1987 Trans am GTA
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Re: Iroc-z Dies while driving on the Highway(HELP)
Also a good chance the coil is acting up when it gets hot. I would start there, check for spark when it dies, however with the chugging before it dies , most likely fuel related.
Old Jul 18, 2011 | 05:50 AM
Iroc87Stud's Avatar
yea i was thinking it might be the coil,module or fuel pump, one of them..they look old so ill prob just replace all three since their not expensive.....do ya know of a good aftermarket module...
Old Jul 18, 2011 | 06:31 AM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
module has alot to do with injectors, try ohming out your injectors when hot? i had a similar issue that turned out to be injectors one time then my maf the next. my modules have given me heat related problems but i carry 2 with me at all times since then. next time it does that try unplugging your maf and see if itll start right up. if not then your maf is cleared. there are some pretty good aftermarket modules out there but just remember to use the heat sink grease. hope that helps yah even the slightest man.
Old Jul 18, 2011 | 07:08 AM
Iroc87Stud's Avatar
I'll do that i just hate sitting on the side of the highway waitin for her to start back up so i might try to let her run in the driveway and see if it cuts off...ill try something...
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
Andrew6.688
Dec 13, 2015 10:59 AM
zeitghaist
Aug 18, 2015 07:33 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
