injectors
Old Jul 18, 2011 | 09:32 PM
znate's Avatar
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.73 posi
injectors
any one ever use 350 injectors in a 305? i have a 305 and the injectors r bad but i have two sets of 350 injectors will they work. my ecm has a hypretec chip will that have any effects on the way it runs? any help is greatly appreciated.
Old Jul 19, 2011 | 03:10 PM
Yager90IROC's Avatar
Car: 1990 Camaro IROC-Z28
Engine: Stock L98
Transmission: 700R-4
Re: injectors
I'm no expert like others on the board, but from what I've read on the board you should be fine. Stock 305 injectors are 19lbs and 350 injectors were rated at 22lbs.
IIRC the computer regulates the amount of fuel delivered so the small difference between the two injectors shouldnt affect performance.
I do know that you wont be able to fully take advantage of the larger injectors without a tune
Old Jul 19, 2011 | 04:56 PM
southbay08's Avatar
Re: injectors
You can run 22lb injectors on a 305,,, you just may not get optimal performance/fuel consumption
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
