TPI Tuned Port dead cylinder help!
Old Jul 19, 2011 | 07:19 AM
ranchodakota's Avatar
I have a 350 with tuned port. New 22lb injectors, new harness and computer from larry's electric, chip with vats removed, brand new blaster 2 coil, msd 6al, and msd pro billet dist P/N 8366. My # 7 cylinder is dead on the drivers side rear. I have tried 3 spark plugs and they all come out wet with fuel. I am getting spark through the wires and the spark plug. I have a pretty large vacuum leak in between # 3 and # 5 cylinder where the cold start inject is. It is plugged but seems to be not good enough. Could this cause a dead cylinder? I know the map and 02 sensors are reading incorrectly with this leak. I had a carb on it and it ran great. thanks
Old Jul 20, 2011 | 07:33 AM
Re: TPI Tuned Port dead cylinder help!
anyone?
Old Jul 20, 2011 | 09:54 AM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
compression check?
Old Jul 20, 2011 | 11:09 AM
great. ran good with carb new summit towing cam and heads where jst off and checked. new rings to.
Old Jul 20, 2011 | 05:01 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
maybe a defective wiring harness ?
Old Jul 21, 2011 | 05:04 AM
Sorry, I got bit again assuming that just because its new its always good. I got a brand new msd dist. and the module was bad last week, got another one under warrenty its fine. So now the new injectors this week. One guy under any amount of pressure sprays, not leaks, sprays so found it. Thanks
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Jake_92RS
Aug 11, 2015 10:39 AM
