vortec 305 heads on tpi?
Old Jul 24, 2011 | 02:21 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Would the vortec L30 305 heads fit on a 305 tpi intake without any work done? and would it increase power cause they flow better? and if it needs a special adapter plate which one, how much, and if you could give me a link that would be great! or is there a way to have a machine shop make the stock tpi work? Thank you in advance!
Old Jul 27, 2011 | 03:53 PM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: vortec 305 heads on tpi?
IIRC, Scoggins Dickey sells a Vortec TPI intake. They are not cheap- $400. Edelbrock has one also, but it is even more money. No realistic way to modify your current intake. If I was going that direction, I think I would do the 350 Vortec heads instead.
Old Jul 27, 2011 | 09:23 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
TPI intake ports don't match Vortec head ports as well as bolt pattern ( 4 instead of 6 )needs changing
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
gta90
Sep 15, 2015 04:00 PM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
