Still Idling low after IAC adjustment
Old Jul 24, 2011 | 12:22 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
So I did the IAC adjustment written by vader and followed it EXACTLY as written.
Paperclip and ECM in diagnostic mode > Wait 30 secs and unplug IAC; turn off ignition and remove paperclip > Unplug timing bypass connector and start engine.
At first, the engine died right out as soon as I let my foot off the gas. No problem, let's open that screw up some. So I adjusted it to 500RPM with the transmission in DRIVE (This may or may not make a difference but I do have a 3000RPM converter), then plugged the bypass connector and IAC back in and started the engine.
Now, this is what it does (On a warm motor). When you first fire the car up it will go to 1000RPM as it should for a few seconds, then it will drop down to about 650RPM; exactly where it should be. It will idle like this fine for a minute or two, but then it kicks down again to 500RPM and seems to favor that for idle speed.
This IAC is brand new. I purchased it as a NOS replacement from TPI parts. All the passages in the throttlebody have been cleaned. WTF is going on!?
Old Jul 25, 2011 | 10:12 PM
A K racin's Avatar
Re: Still Idling low after IAC adjustment
I am having the exact same problem and took the exact same steps with no luck hopefully someone can shine some light on this and help us out
Old Jul 27, 2011 | 03:42 PM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
It's been a while, but I remember going through this. IIRC it was an iterative process, involving adjusting the IAC, and then adjusting the TPS. Took several tries to get it to settle down. HTH
Old Jul 28, 2011 | 06:02 PM
Damon's Avatar
Not sure about 85 but in 86 that was the commanded idle speed. And like 450 in gear (automatic trans car).
If that's what the chip is progammed for that's what it's going to idle down to unless you open the throttle plate adjustment so much it idles higher than that even when the IAC valve is fully closed.
specialized
Jun 18, 2022 09:26 AM
db057
Sep 4, 2015 07:57 AM
86IROC112
Aug 21, 2015 07:20 PM
perZ
Aug 21, 2015 05:51 PM
perZ
Aug 15, 2015 01:17 PM
