tpi swap help
Old Aug 9, 2011 | 07:59 PM
sicmu355's Avatar
tpi swap help
I have a connector i cannot figure out what it goes to. its in the cooling fan harness it is a 3 terminal connector, EX: ABC, A is a red wire and C is an orange wire B cavity is empty. the 20A inline fuse and A/C pressure switch connectors are also close by in this harness i hope this helps. I'd really like to know what it goes to Thanks for the help
Old Aug 9, 2011 | 08:02 PM
jimmy_pop15's Avatar
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
Re: tpi swap help
a picture may help us out
Old Aug 9, 2011 | 08:45 PM
sicmu355's Avatar
Re: tpi swap help
hope this helps
Old Aug 10, 2011 | 08:39 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: tpi swap help
Originally Posted by sicmu355
hope this helps
What is harness out of?
Old Aug 10, 2011 | 12:18 PM
sicmu355's Avatar
Re: tpi swap help
92 camaro
Old Aug 10, 2011 | 07:44 PM
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
Re: tpi swap help
The heavy gauge wire would make me think it's for another fan. maybe your car had dual fans before?
Old Aug 11, 2011 | 07:50 PM
sicmu355's Avatar
Re: tpi swap help
I t does have dual fans those 2 connectors are after the one in question. The wiring diagram show a heavy duty coolant fan relay with 2 wires going to it One is orange and the other is brown i wondered if the diagram colors were wrong but i've never seen a relay with only 2 wires to it so if thats the case i still don't know the purpose of the relay
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
