Fuel Pump Question
Old Aug 10, 2011 | 03:12 PM
Calaban007's Avatar
Car: 95 Z28/IROC-Z
Engine: LT1/L98
Transmission: 6 Speed/700R4
Axle/Gears: 3.42/2.77 Boo!
Fuel Pump Question
My fuel pump is dead in my 89 IROC-Z TPI 350. The small amount of gas in the tank smells like varnish. I'm sure it gummed up the fuel pump. I know for a fact after troubleshooting that the fuel pump is not working.
I have a new fuel pump. It is an aftermarket no name. I can't remember if it came with a new plug to wire into the factory setup since I've had it for over a year and have move it a couple of times.
What does the factory fuel pump socket look like. I should have taken a picture but the one on the new pump is about 3/4 inch long and about 1/2 wide with 2 prongs in it. Does this sound right?
Also, what can I use to clean out the tank before I put it all back together? Will fresh gas breakdown what's in it? I mean whatever I do, I will want to make sure the tank is empty and completely clean when reinstalling it. Then add about 2 or 3 gallons of fresh gas and see if it will start.
Old Aug 10, 2011 | 04:38 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: Fuel Pump Question
Does this help at all?
Old Aug 10, 2011 | 05:31 PM
Calaban007's Avatar
Car: 95 Z28/IROC-Z
Engine: LT1/L98
Yes, very much.
It looks about the same size as the one I have.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
