It has been awhile since I had a TPI question
Old Aug 14, 2011 | 03:16 PM
Kevin G's Avatar
Back in the day I ran an Accel Super Ram intake setup and I started looking around what they go for these days. I only see Accel makes the base now and not the full setup? Did they stop making the Super Ram setup?
Is the Holley Stealth Ram the intake to go with these days?
Old Aug 15, 2011 | 01:16 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: It has been awhile since I had a TPI question
I do believe they stopped making the super ram a long while back. I didnt know they still had the bases. Not sure why anyone would stop producing that intake... if they made that setup using intake studs instead of bolts to make it easier to install, and used larger diameter runners/base like the FIRST tpi, it would be a phenomenal setup.
HSR is a good option these days tho, its cheaper and performs abit better, and responds well to alittle porting. There are other options like single plane EFI, edelbrock proflo xt, etc. All depends on what the engine is designed to do.
fasteddi
Sep 2, 2015 10:29 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
BOOT77
Aug 10, 2015 12:20 PM
