got no spark
got no spark
i cant figure this one out, i have no spark coming from coil, coil was replaced 4 months ago with msd blaster, car quit and i new that i had to replace the injectors so i removed lower intake to have cleaned and resealed while i was that far into it, i didnt check for reason it quit befor doing this, dont know what is wrong is there suposed to be power to all four wires going into the coil, because ther is, with key on, modual inside dist is good had it tested, noticed that the outer brassy part of what i think is the pickup coil can be turned a little bit should it be solid, car had ecm replaced 3 months ago, as well idle air control, tps, map sensor, ect sensor, plugs wires cap and rotor, i also removed emissions pump while i was doing this, its a 91 ta with 305 tpi, has any one heard of such a problem, any help would be appreciated,
Car: 92 L98 Z28 Heritage Hard Top
Engine: L98 350 w/ HSR,24lbs inj,AFPR
Transmission: TCI Super Street Fighter W/3300 sta
Axle/Gears: 3.73 Detriot NoSpin,LPW cover
Re: got no spark
It's most likely the distributor, the magnetic coil in the distributor gets rusty and stops working, think of it as a camshaft position sensor for the coil. Hope that helps, I have the same problem with my car and am getting a MSD Street-Fire distributor for my car.
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
