hp and torque estimate
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Hello i was wondering how much power people would estimate my tpi build to be without my nitrous cause i can add 75-125 to whatever the outcome is. all my mods are in my sig if not detailed enough there, its better described in my profile. i have stock exhaust manifolds but thought with a straight through exhaust like the one i have that wouldnt cause to much power loss and i would keep some low end with them.
Car: IROC Z
Engine: 5.7
Re: hp and torque estimate
http://www.gmtips.com/3rd-degree/dox/tips/cams/cams.htm
find what you are starting with, then add 15hp
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Why would it only be adding 15 cause on that site of info it went through many problems and i have fixed everything it said i even have replaced the whole ecm. and why does the 86 auto tpi have a 9.5 to 1 compression and the rest have 9.3 to 1 is it different heads or? mine is the hotter cam tpi 305 with 215hp and 295ft Ib.
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
really the only thing i havent changed is the heads and exhaust manifolds and i dont think that will hold a motor back that much.
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
You have a TPI and a 305. Take it from me who has the same block and intake that you NEED a set of heads. Stock 305 heads aren't all that great. Stock TPI falls off in the mid to high 4000 range but if you open up the plenum. get a high flow runner set and base manifold those heads are really going to be holding you back. The exhaust manifolds will also choke all of that once you're able to pull past 5k. You need all the parts properly matched to each other. One single restriction bottlenecks the whole motor.
Car: '87 Z-28
Engine: LT1-topped 400
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
the costum side skirt is a true dual so i dont need a y pipe and the intake i did replaced the 1 by 3 inch box it takes air from and put 3'' pvc pipe so it seems like it would open that to have no restriction.
Car: '87 Z-28
So you did replace the headers then? Add another ten horse to the previous number.
no green
Jan 9, 2016 09:22 PM
