car will not start, injector problem, hope there is some well knowledged people out t
Old Aug 23, 2011 | 12:41 PM
cta1991's Avatar
i have a 91 ta with 305 tpi, car will not start, had replaced injectors with orange topped ones from a mustang injector resistance is 16.2 ohms car will not start, checked resistance acros injector conectors and they are like 5.0 ohms, as well the conector ends are showing continuity to ground on both sides of conector, dont know what all these things should have for resistance, or if conector ends should have continuity to ground on both sides i have a feeling that they should not be
Old Aug 23, 2011 | 05:28 PM
67hotrod's Avatar
Car: Camaro
Engine: 6.0L LQ4
Transmission: 4l80E
Axle/Gears: 12bolt 3:42
Re: car will not start, injector problem, hope there is some well knowledged people o
check your injector fuse. It may be the ECM fuse. Did it ever run with those injectors or just wont start after changing the injectors?
Old Aug 27, 2011 | 01:17 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Each bank of injectors are powered by separate fuses, this power is switched to ground by the ECM so with an injector disconnected and the key on there should be 12volts on one pin of the connector, but not the other which should show infinite resistance to ground (an open circuit) when measured for resistance. The injector resistance should be measured disconnected from the wiring harness, you should take measurements when cold and hot to ensure they're not crapping out when hot. The fuse is a 5amp fuse each bank draws approx 3 amps (12 volts/16 ohms =.75 amps x 4 = 3 amps.)
If your injectors are really 5 ohms each the total draw per bank is 9.6amps (12 volts/5 ohms = 2.4 amps x 4 = 9.6 amps) and would blow the fuse immediately.
Old Aug 27, 2011 | 09:37 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
are they 16.2 ohms or 5 ohms? which one? They should all be around the same
Old Aug 27, 2011 | 09:39 AM
ninetyone's Avatar
Axle/Gears: 3:42
http://www.youtube.com/watch?v=_g8PdrT0MCU
check that link.
bryan623
Mar 22, 2021 06:43 PM
midge54
Dec 27, 2019 04:14 PM
justin57
Aug 20, 2015 07:05 PM
killer777
Aug 8, 2015 02:47 PM
mustangman65_79
Aug 8, 2015 12:07 PM
