OBDII code
Old Aug 27, 2011 | 11:37 PM
92camaroz28ss's Avatar
Car: 92 z28
Engine: fast burn 385
Transmission: t56
OBDII code
I have had a cel on for a while now. I pulled it yesterday and it gave me p01345 which is something like Crankshaft position sensor / Camshaft position sensor correlation. I did a little searching online and found some gm truck guys talking about the gear on the distributor wearing, timing being, or timing chain stretching. I only have about 30k or so miles on this engine, so i guess its not the timing chain. When i did the OBDII swap, I couldn't afford a real good distributor so i went with a cheap one. I'm not sure if this has something to do with it, or something with the cam sensor. Does anyone have any info onthis? It's a 92 camaro with a 350 tpi and was switched to OBDII. It also runs like crap and misses at low speeds especially when cold, but smooths out a little when it warms up. It also gave me a temp sensor code, which i assume is why one of my fans wont turn on now, but i don't think this is related
Old Aug 28, 2011 | 05:19 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: OBDII code
So seeing that no TPI engines were OBD2 , what computer / harness / dist are you running now ?????
OBD2 only came on 96/97 LT1 cars with Optispark dist
Old Aug 28, 2011 | 09:45 AM
Car: 92 z28
Transmission: t56
Re: OBDII code
i did the obdII conversion from these boards. It has a dizzy from an 01 express van, computer from an 02 LS1 4th gen (also ran all of the trucks from 02-04 but i cant remember the part number right now) and a harness from efi connection specifically for these cars and an obdII conversion.
I'm pretty sure it did not have this light on when i originally did the conversion, but it has been on for a while now.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
