Correct ECM
Old Aug 28, 2011 | 01:44 PM
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
Correct ECM
Whats the correct ECM for a 91 Z/28 350 TPI with the 700R4 but doing a 5 speed swap? The tranny I'm getting I'm told is from an 87 TA so I'm not sure if the tranny has a cable drive or is electronic for the speedometer. I am almost clueless when it comes to ECMs.
Old Sep 9, 2011 | 08:28 PM
Car: 1991 red Z/28
Re: Correct ECM
There has to be somebody on here who is knowledgable. I've done searches on here and cant find what I am looking for.
Old Sep 9, 2011 | 08:56 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Correct ECM
a 91 should have the 7730 ECM with an AUJP MEMCAL.
the trans coming from a TA may not have used a speed cable.
i know a good number of the TAs used electronic speedometers but i don't know what the model years are.
but swapping it out to a cable drive shouldn't be to big of a deal.
because GM never put a standard trans behind the 350 TPI, they never made a chip for it. so getting a chip burned with S_AUJP_V4 thats set up for a standard would probably be the best way to go.
Old Sep 9, 2011 | 10:29 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Correct ECM
If cable drive you can use this to supply correct signal for '730 ECM
http://tpiparts.net/inc/sdetail/10956/7587
Old Sep 10, 2011 | 11:27 AM
Car: 1991 red Z/28
Re: Correct ECM
Thanks guys...big help. I saved the TPIP Parts page.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
skeltor
Feb 2, 2016 10:37 AM
Ranbo108
Sep 9, 2015 12:20 PM
Jlanz55
Sep 8, 2015 11:28 PM
89fast5oh
Sep 8, 2015 09:55 AM
