Fuel injector question
Old Sep 5, 2011 | 12:40 PM
rrwebster's Avatar
Car: 88 GTA
Transmission: 700 R4
Axle/Gears: stock
I bought a set of Fuel injectors off Ebay that didn't have the box... so they were cheap.. the bag was not opened and it did appear to be the origianal.
My question is this... where there was a lock on my old injectors that you had to turn to remove them; these have a blue plastic ring where the lock is on mine.
Is it safe to install them this way or should I try to find some locks?
Old Sep 5, 2011 | 05:35 PM
southbay08's Avatar
Re: Fuel injector question
which injectors are they?
Old Sep 5, 2011 | 05:53 PM
rrwebster's Avatar
Car: 88 GTA
Axle/Gears: stock
The fuel injectors that go between the fuel rail and the intake.
Old Sep 5, 2011 | 06:15 PM
southbay08's Avatar
Ok, let's try this again LOL,
what brand are they? Do you have a part number?
Want to see what you are talking about with the "blue plastic ring"
Old Sep 5, 2011 | 06:26 PM
rrwebster's Avatar
Car: 88 GTA
Axle/Gears: stock
Oh! lol
I've no clue... they were from ebay without a box... the shipment came from Chicago Corvette supply... they are solid blue in color and the ebay ad said they were for a 305... here is what the ad says
UP FOR SALE IS THIS BRAND NEW SET OF 8 STANDARD PRODUTS FJ8 FUEL INJECTORS [UNBOXED] USED ON TPI SYSTEMS ON 305" MOTORS IN CHEVROLET CAMAROS AND PONTIAC FIREBIRDS. THEY ARE IDENTICAL TO ORIGINAL EQUIPMENT! FREE SHPG IN THE CONTINENTAL US FJ8X8
Old Sep 5, 2011 | 06:44 PM
rrwebster's Avatar
Car: 88 GTA
Axle/Gears: stock
well, I did a web search and I see that the blue ring has nothing to do with the locks... the spot for the lock is there also...
Old Sep 6, 2011 | 05:00 AM
rrwebster's Avatar
Car: 88 GTA
Axle/Gears: stock
http://www.summitracing.com/parts/SMP-FJ8/?rtype=10
Here is a picture of the injectors I have.... you can see the blue ring.
back to my original question.
is it safe to use these without the lock ring?
Old Sep 6, 2011 | 01:34 PM
mlynch001's Avatar
Car: 1985 El Camino SS, 2004 Trailblazer
Engine: Hybrid 305, 91 SD TPI, lots of mods
Transmission: 200-4R
You need to find a way to limit the downward travel of the injector. The locks are to keep the injectors in the rail and properly position the injector nozzles. I am using 4.6 19lb FORD Series 3 injectors without locks. I have O rings at the bottom of the injectors, between the manifold and the injector. This positions the injector nozzles and also keeps the injectors from "blowing out" of the rail from fuel pressure. Fuel pressure and manifold vacuum are pushing and pulling (respectively) the injectors down against the O-rings and against the manifold. This additional o-ring that I used is keeping the injector from moving "too far" down and out of the rail at the top.
Old Sep 6, 2011 | 05:07 PM
southbay08's Avatar
Originally Posted by mlynch001
You need to find a way to limit the downward travel of the injector. The locks are to keep the injectors in the rail and properly position the injector nozzles. I am using 4.6 19lb FORD Series 3 injectors without locks. I have O rings at the bottom of the injectors, between the manifold and the injector. This positions the injector nozzles and also keeps the injectors from "blowing out" of the rail from fuel pressure. Fuel pressure and manifold vacuum are pushing and pulling (respectively) the injectors down against the O-rings and against the manifold. This is keeping the injector from moving "too far" down and out of the rail at the top.
After looking at the pic of the injector, you will not be able to add
another oring to the bottom....there is nowhere to put it. You are going to have to get yourself a set of clips because i am sure that they are not going to be long enough to seat properly in the rail.
Old Sep 6, 2011 | 05:58 PM
mlynch001's Avatar
The O-rings that you add are placed on the lower shank of the all the way up against the body, between the body of the injector and the top of the boss of the injector port in the manifold. They do not fit into grooves in the injectors. These are in addition to the factory o-rings that seal the injector to the intake port boss.
I am trying to post a close-up and normal picture of my intake and injectors and show you what I have done. The camera does not have a real good "macro mode" but you can see the o ring between the injector and the intake if you look close. Pictures below.
Mine works perfect and DOES NOT use clips! I trial fit the whole thing up on the bare intake and made sure that the injectors were positioned properly AND pressure tested to 120 PSI. So I know this works and is safe, my El Camino has run 3000 miles without a problem.
http://www.facebook.com/photo.php?fb...type=1&theater This is a "normal" view of the engine out of the car.
http://www.facebook.com/photo.php?fb...6134192&type=1 This is a really crappy "close up" view, taken today. You can see the o-rings that I am using to keep the injectors spaced properly in the intake ports AND keeping them from "blowing out" of the fuel rail under pressure.
MustangBeater20
Oct 29, 2022 09:20 PM
bryan623
Mar 22, 2021 06:43 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
