Porting a TPI intake. How and is it worth it?
Old Sep 20, 2011 | 10:29 AM
macmatt's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Hey guys. I have obtained a tpi intake setup to convert my firebird from a 305 tbi to a 350 TPI. I was wondering about how you would go about porting and polishing the intake plenum and runners. Or if it would be worth the effort.
My plenum currently looks like this
Note that the holes for the runners are not perfectly round. Is there fix for this? Also, how would you go about smoothing out the inside? Forgive me if these questions sound a little dumb. I am new to Multi Port Injection systems.
Old Sep 22, 2011 | 03:27 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: Porting a TPI intake. How and is it worth it?
I would gasket match it and then send it out to be extrude honed...
Old Sep 23, 2011 | 09:35 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/post...545-post3.html
http://www.austinthirdgen.org/index.php?pid=21
http://www.eecis.udel.edu/~davis/z28/buildup/plenum/
https://www.thirdgen.org/siameseport
Polishing as such is a waste of time as you are not dealing with suspended fuel like on a carb motor.
Just smooth everything out
Old Sep 23, 2011 | 11:35 AM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
I definitely say it's worth it. I got the AS&M large tube runners, matched them to the plenum and base, 52mm TB and matched it to the throttle body, had the Super Ram manifold ported and smoothed about 2" in. Along with the accompanying fuel/chip/exhaust (see my sig) mods, my car made around 330hp/499tq at the flywheel. Not too shabby considering the Dart 165 heads I run.
Old Sep 24, 2011 | 03:29 PM
12SecTPIguy's Avatar
Car: 92Z28
Engine: 350 Stock Runnered TPI
I siamese ported the manifold on mine gasket matched the plenum and radiused the inlets to the stock runners. Stock, ported heads and it runs 12s. I'd say get out the die grinder.
Old Sep 24, 2011 | 09:23 PM
macmatt's Avatar
Engine: 305 TBI
Thanks for all the suggestions guys. As soon as the funds allow I'll be getting started on this stuff. Keep 'em coming!
Fast355
Dec 2, 2016 06:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
masonta
Aug 31, 2015 10:14 PM
355tpipickup
Aug 13, 2015 07:35 AM
Sanjay
Aug 12, 2015 03:41 PM
