vacuum leak?
Old Sep 21, 2011 | 05:05 PM
lowbird's Avatar
Car: 88 firebird
Engine: 350tpi
Axle/Gears: 373
vacuum leak?
is it just me or does everybodys tpi sound like it has a vacuum leak ? I have a high idle and I was checking but it is constant . I don't have a leak I was just curious .
Old Sep 21, 2011 | 07:52 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: vacuum leak?
What is a high idle? what RPM, any codes? check for a vacuum leak around the throttle butterfly shaft. How do you know you have no leaks? What all have you checked? Sorry for all the questions, but the more info the more we can help.
Old Sep 21, 2011 | 09:14 PM
lowbird's Avatar
Car: 88 firebird
Engine: 350tpi
Axle/Gears: 373
Re: vacuum leak?
It's 1800 .I checked with brake cleaner found no leaks .no codes but I loosened the tps and moved it and it droped .the throttle body is new its something to do with that tps .when the car is running I sware I here a leak so is was wondering it that's how you's just sound?.its sounds like air moving through the runners? I switch this car from 305 tbi to 350 tpi and I have had a ton of problems.
Old Sep 21, 2011 | 09:35 PM
red rock's Avatar
Car: 1987 iroc
Re: vacuum leak?
First the TPS should be between .54 and .75 volts, https://www.thirdgen.org/tpimod2 ,also adjust the IAC as described in link. I like .65 volts. As for air leaks, you can by an automotive stethascope for cheap or use a peice of small hose to your ear and move around at different gaskets. Are all vacuum lines attached and not broke? Where do you think you hear the leak from?
Old Sep 22, 2011 | 12:12 PM
lowbird's Avatar
Car: 88 firebird
Engine: 350tpi
Axle/Gears: 373
Re: vacuum leak?
Im going to pull the intake because of an oil leak at the back anyway. Hope i'll find it then.
FormulasOnly
Jul 23, 2018 08:47 AM
bbsr72
Apr 2, 2016 09:12 AM
jrdturbo
Mar 31, 2016 02:58 PM
86maro_252
Oct 10, 2015 06:52 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
