TB Question
Old Sep 27, 2011 | 04:02 PM
TMMYJMMY's Avatar
Car: 1989 IROC
Engine: 5.7
Transmission: AUTOMATIC
Axle/Gears: POSI
TB Question
So I'm in the middle of a 383, and we decided to bore out the throttle body. Now my concern is the little hole on the right side, up top; the disk covers the hole. However after boring the TB out the hole was enlarged, so my question is if this will cause any problems?
Old Sep 27, 2011 | 07:42 PM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Re: TB Question
Pictures are always good.
Old Sep 27, 2011 | 08:35 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: TB Question
Thats a idle air bypass. You may have a high idle unless u make the hole smaller,use a 2part epoxy. Thats what I did.
Old Sep 28, 2011 | 01:00 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TB Question
I don't see a problem unless it allows air to leak past the blades when they are closed.
Is only the source for the small vac tube under drv side of TB
Old Sep 28, 2011 | 11:59 AM
TMMYJMMY's Avatar
Car: 1989 IROC
Engine: 5.7
Axle/Gears: POSI
Re: TB Question
Here are the pictures and it will let air through it. we bored it out to 52mm I believe.
Attached Thumbnails TB Question-img_4375.jpg   TB Question-img_4374.jpg   TB Question-img_4372.jpg
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
