305tpi/350tpi swap
Car: 86 Camaro Coupe
Engine: currently building a 355
Transmission: unsure what it will end up with
Axle/Gears: 10 Bolt 2.73
305tpi/350tpi swap
I have a 305 tpi motor in an 88 iroc if i take out the 305 block and put the 350 from another vehicle in it will i have to swap out the computer as well so it runs with the tpi set up?
Car: 86 Z28
Axle/Gears: 3.42 posi
Re: 305tpi/350tpi swap
no it will run but not properly. You will need 22 lb/hr injectors, computer chip, 350 knock sensor, and esc module for it to run better, or burn your own chip if the motor is more then stock.
Hello, Michael
Aug 20, 2015 03:19 PM
