injectors question
Old Oct 18, 2011 | 08:43 PM
soxbaseball's Avatar
injectors question
Can you use 22lbs injectors in a stock 305 tpi setup?
Old Oct 18, 2011 | 08:47 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Re: injectors question
Not without computer work.
Stock injectors are 19lbs. If you put bigger injectors in and dont do any mods you will run into problems.
Old Oct 18, 2011 | 08:51 PM
Ok that's what I thought just wanted to be sure. Thank
Old Oct 18, 2011 | 10:22 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
They will work just fine
Old Oct 18, 2011 | 11:10 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
i wouldn't do it, you will be running overly rich and lose power. they will work if you re-tune the chip (prom).
MustangBeater20
Oct 29, 2022 09:20 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
