update about Dads GTA and injector question
Old Oct 27, 2011 | 06:37 AM
TOPLSFOX's Avatar
Ok so I figured out why his car ran like crap after it warmed up and wouldn't start hot. I couldn't get any correct OHM readings of the injectors that made any sense good or bad so started checking around the computer and found the computer ground was bad. After I fixed that car ran same but would start no matter how hot it was. So then I rechecked injectors and found cyl 1 6 and 8 we're 9 10 and 11 ohms. The rest were 17 to 18. I know anything under 12 is done so I'm pretty sure I've found the other part of problem to get car running properly. My question is this. Are the injectors from my 89 5.0 the same as the injectors in his 305 and will they work in his trans am. I'm running 24lbs on boost now and know my stock 19lbs ones are fine.
gta90
Sep 15, 2015 04:00 PM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
