no injector pulse after warmed up
Old Oct 29, 2011 | 04:32 PM
grasshoppertym's Avatar
Car: 87 iroc
Engine: 305 tpi
Transmission: auto
Axle/Gears: 3.23 limited slip
so i have had this problem for awhile now and my mechanic has fixed a few sensors and wires and complete tune up and now it starts adn runs fine until it warms up (maybe 20 mins idle) and stalls, and will crank but not start. they have traced it to no injector pulse, lots of fuel pressure but no pulse. any ideas, anyone
Old Oct 29, 2011 | 09:58 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: no injector pulse after warmed up
Interesting problem. The injectors are batch fired, each bank pulsed separate from the ECM so I'd rule out that. Two separate power feed circuits. Something is telling the ECM not to pulse the injectors. I wonder if the ignition module is heating up and not sending an RPM signal to the ECM?
Old Oct 29, 2011 | 10:20 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
I would check to see if you have spark at the same time you loose the inj pulse.
Old Oct 30, 2011 | 07:23 AM
Car: 87 iroc
Engine: 305 tpi
Transmission: auto
yes there is spark
spark control modual was changed the last time it died on me thinking that was the problem but still happening also done at the same time was
plugs
wires
cap rotor
oil change
mass air flow cleaned up
temp sensor
and i changed out the ecm with a new remanufactured unit before it went to the shop
92-Formula
Dec 12, 2015 10:34 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
amcnellis
Sep 16, 2015 04:16 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
