Can't Fix this Random Misfire
Old Oct 31, 2011 | 01:22 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Im sure youre all sick of seeing the same threads from me but Ill put this as simple as I can. I have a random misfire from one cylinder. I have changed:
-Plugs
-Wires
-Cap
-Rotor
-Injectors
-All 8 injector connectors
First crank up of the day, smooth as glass, for about a minute, then starts loping. While accelerating or cruising I can hear the engine gain and lose power from one cylinder. Sometimes it runs so smooth the tach doesnt move at idle. Rock solid. Then a few minutes later it will start missing while cruising or idling...the whole exhaust system will shudder and the tach wiggles in tune with the miss. Then it will snap out of it and run smooth again for a few minutes.
I found cyl 3 and 5 had oil fouled plugs as shown here.
The rest looked normal. Changed the 2 bad plugs with good ones, and it doesnt fix the problem. Still random misfires. Sometimes smooth, sometimes rough.
I want a good used LB9 to swap in.
Any help would be great.
Old Oct 31, 2011 | 02:06 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Can't Fix this Random Misfire
It might be a problem with the fuel injection pulses to those 2 cylinders. That should be easy to see with a scope since they should all be the same width otherwise it would be an ignition problem. You could try indexing the plugs to see if the spark might be blown out ocassionally.
Old Oct 31, 2011 | 02:42 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
I am convinced its not fuel. They are Bosch III with all new connectors, which I noid checked and were good. I had this problem before I changed the injectors.
How do I index the plugs and check for blowout? You mean gap them?
Thanks for the help so far.
Old Oct 31, 2011 | 02:55 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
To index first mark the white porcelain inline with the open end of the gap reinstall and see if the gap is pointing towards the intake valve if so use copper indexing washes to point it away, or just put plugs that can be gasped to .035 to minimize the distance the spark has to jump.
Old Oct 31, 2011 | 03:08 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
I see. I will try that. Since I am convinced it has something to do with these two plugs that keep fouling.
But I am wondering why they foul like that so bad? Those plugs had around 2000 miles on them when I pulled them. And these were the same two plugs that were fouled when I bought the car. Bad rings or valve seals?
Old Oct 31, 2011 | 03:19 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
You always want to do easiest & less expensive things first. So do a cylinder leak down test if they are leaking add a squirt of oil to determine if it's the rings or valves
92firebirdguy
Sep 1, 2016 07:53 AM
camarohelp
Sep 22, 2015 03:19 PM
BWilcox
Sep 20, 2015 12:19 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
Jk_Under
Sep 8, 2015 08:13 AM
