MAF vs speed density?
Old Nov 25, 2011 | 10:04 PM
RicerEater78's Avatar
I'm sure the question has been asked before (yes i searched) or maybe its just a stupid one no one has to ask. I'm going to be starting a tbi to tpi swap on my 350. when I picked up the intake, wiring and ecm today, the guys said I could use maf or speed density? I'm kinda new to fuel injection but I have a basic understanding of how each of these works. but which is better? can you run both? which does the car come with from the factory?
Old Nov 25, 2011 | 10:27 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: MAF vs speed density?
You say you picked up the ECM and wiring harness, which was it MAF or SD?
'85-'89 was MAF '90-'92 was SD. The ECM makes the determination.
Old Nov 25, 2011 | 10:38 PM
perfect, that's exactly what I was looking for. the one I got was maf. is this preferred over speed density or should I find a new ecm?
Old Nov 26, 2011 | 09:30 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
MAF is easier to tune, especially if you have or plan to have mods to the engine. SD requires much more tuning, but is a simpler install for the intake hoses. Since you already have the MAF ECM, I would go that way.
Old Nov 27, 2011 | 02:04 AM
alright, thanks!
Old Jul 24, 2013 | 03:52 PM
ramicio's Avatar
Car: '87 Flame Red/Carmine Red GTA
I read the article about converting to MAP. Why does it go on about tuning? Can you just get an ECU and re-pin the harness if you just plan on keeping a stock car? Do you still need to change the memcal thing in the ECU?
Old Jul 24, 2013 | 09:52 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Completely different setups .
You can rework the wiring harness but you need the correct ECM (MAP vs MAF ) and it's corresponding tune in order for everything to work correctly
Even though the 165 and 730 use identical looking memcals that will physically swap between the two ECM's ,
the tune and other things on the memcals are different
Old Jul 24, 2013 | 10:13 PM
ramicio's Avatar
I know they're different setups, but I don't get why you can't just get a MAP ECU for a 350 and put it and the harness and whatever sensors are different in a 350 MAF car. Or am I just misunderstanding this?
Old Jul 24, 2013 | 10:22 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Because there is no such thing
The MAP ECM is a '730 used on many different cars.
It is the tune on the memcal inside that determines what it is actually set up for ; 305 or 350 , auto or stick .
Many will sell a "350 ECM " when it has a 305 or V6 memcal in it
That can only be determined by reading the 4 letter code on the silver label inside the memcal.
Old Jul 24, 2013 | 10:24 PM
ramicio's Avatar
So the 350 just stayed MAF? I'm really not getting this...
BumpaD82
Feb 26, 2016 02:57 PM
Nick McCardle
Sep 10, 2015 08:36 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
