New Bosch III Injectors.... ?'s
Subscribe
Dec 19, 2011 | 05:29 AM
http://fuelinjectorconnection.com/sh...od&productId=4
Was told these are a direct drop in, 60mm...
Are the stock multech's that size too? I know some of the other Bosch III's have an adapter or modified housing to fit ???
I have a 305, but I can tune the computer, there shouldn't be a problem, correct?
I know a few companies sell rebuilt, but I would just prefer new...
Thanks,
Rafael
Reply 0
Dec 19, 2011 | 09:53 AM
Re: New Bosch III Injectors.... ?'s
Found these (new) even cheaper...
Seems these are EV1's, not the same as the other Bosch III designed that have adapter or case mod to fit stock multech lengths...
Says in ad that they are 74mm in length...
http://www.ebay.com/itm/270715542195...84.m1438.l2649
Anyone?
Reply 0
Dec 19, 2011 | 10:24 AM
Anyone?
According to Bosch:
http://www.bosch.com.au/content/lang...linjectors.pdf
They flow 16.4 #/hr at 50.1 psi. This is the 0-280-156-013 injector, same part number listed on the eBay ad.
RBob.
Reply 0
Dec 19, 2011 | 02:23 PM
So they do not flow 24lb?
I would take this as a "no, will not work"?
Rafael
Reply 0
Dec 19, 2011 | 03:58 PM
Anyone?
Cheaper? I don't think so. I bought
my bosch iii's at FIC 2 years ago. I got them for only $150. $288 sounds right for a set of brand new ones. But if they are reman Bosch injectors, and go for over $200, then who ever buys them is getting ripped off.
Reply 0
Dec 19, 2011 | 04:12 PM
Rafael
Don't know, only listed what I found and where. Figured that a Bosch data sheet was a good start as to what they really are. Maybe the data sheet is incorrect, maybe the part number listed in the ad is incorrect.
Note also that the difference between 60 mm (first posted inj's) and 74 mm is over a half inch. Good possibility that the measurements are from two different locations on the injector.
Such as o-ring to o-ring versus top to bottom.
RBob.
Reply 0
Dec 19, 2011 | 08:10 PM
Both sellers said would work with L98 Vette, Camaro or Firebird....
Of course, would need tuning with 5.0 LB9....
Reply 0
Dec 19, 2011 | 08:17 PM
I used Southbay Injectors but mine are 36lbs, they do have the 19,22 and 24's in Bosch III, plus they sell reman ones also, my reman 36's have been in the car for a year now no problems at all.
Reply 0
Dec 19, 2011 | 08:18 PM
I do see that part number in the ad, but in the data sheet, it refers to ev6, not an ev1...??
Reply 0
Dec 19, 2011 | 08:19 PM
I would just prefer to go with new ones....
I can tune my computer and when I upgrade to a 350, use the same injectors...
Rafael
Reply 0
Dec 19, 2011 | 09:43 PM
No tune needed. Only mod needed is if you are using a EPROM and you need to change the flow rate by means of Tuner Pro.
Reply 0
Dec 19, 2011 | 10:21 PM
Just phone up Jon at Fuel Injector Connection. I talked to him on the phone for about 30-40 minutes before I bought my injectors. He is glad to answer any questions. He's a real chatty person. Nice guy.
Reply 0
Dec 20, 2011 | 02:50 PM
Anyone?
unless you have an aftermarket intake, those injectors will not be long enough to fit the tpi setup. You will either need our adapter or a double oring set up.
www.southbayfuelinjectors.com
516-492-6504
Reply 0
Dec 20, 2011 | 03:21 PM
Quote: unless you have an aftermarket intake, those injectors will not be long enough to fit the tpi setup. You will either need our adapter or a double oring set up.
516-492-6504
SB, I have a double o ring setup. Will the injectors fit inside my Edelbrock hi flow tpi intake?
Reply 0
Dec 20, 2011 | 03:49 PM
No they will sit too high. You do not need the extra oring. The oring that is above the bottom oring can just be snipped off. You just need the standard length bosch lll
Reply 0
Dec 20, 2011 | 04:05 PM
Quote: No they will sit too high. You do not need the extra oring. The oring that is above the bottom oring can just be snipped off. You just need the standard length bosch lll
Don't wanna hijack the thread SB. Pm sent.
Reply 0
Dec 20, 2011 | 09:55 PM
Well, thanks SouthBay for chiming in...
Offering a better price than anyone else on New 24LB Bosch III injectors
& the 10% off of that price....
Rafael
Reply 0
Subscribe
