Which port goes where
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Which port goes where
the lower goes to the heater core better to bypass the coolant warming up the air going into the tb and just run it directly off the manifold fitting. the large one on top is hooked up to the pass valve cover for crankcase vent you can plug this and put a breather on the valve cover aswell., the middle one goes to the evap canister. If you are not using that install a vacuum plug. the small one on the other side of the tb goes to the egr solenoid than from the solenoid to the egr. if you are not using the egr you will need to plug this port as well and reprogram the memcal code 32 out.
