327 TPI?
Old Dec 25, 2011 | 10:07 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
327 TPI?
Any thoughts on tossing a TPI on a 327? I have the chance to pick up a "cheap" '85 305/700R4 combo so the intake would bolt right up although the injectors would be a touch small. Easy enough to change injectors though.
Of course I'd do the "normal" porting of the intake/runners & throttle body before bolting it all on.
And a custom tune never hurts any engine, just not sure how well it would run with stock programming to start with.
Old Dec 25, 2011 | 10:12 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: 327 TPI?
sounds like a cool build , for your questoin I have no idea, but If the motor and trans will be out you could make it look hella pretty and add a hello kitty sticker to it.
Old Dec 25, 2011 | 10:14 PM
gp90gta's Avatar
Car: 1990 GTA
Re: 327 TPI?
What cam, heads on the 327, most guys I know with 327 build it to rev high since they dont make as much tq and 350-383 and if thats your plan a tpi may not be for you but if your trying to make some extra tq by using a ltr then I would love to see the results so I'm subscribing.
Old Dec 25, 2011 | 10:24 PM
Car: GTA
Re: 327 TPI?
Don't recall which cam, but it is "healthy", drinks gas like nobodies business & the idle is, well....Barely there.
Dunno if it is solid or hydraulic, but either way I'm pretty sure it needs to be swapped for a more EFI-friendly one.
Trans only has 10k on the rebuild & since the TH400 behind the 327 is blown, it needs a new tranny anyways so this would make for a good temporary replacement until the 400 is rebuilt.
It would be a cruiser not a racer, so torque building would be a good thing. If I wanted RPMs, I'd go for a 302. It would be going into a truck anyways & while not exactly a tow truck, the extra torque could come in handy when needed.
Old Dec 26, 2011 | 03:46 PM
BuzzLOL's Avatar
Car: '87 GTA Black/Black/Gold & others
Engine: TPI 350" & others
Transmission: Many
Axle/Gears: Many
Re: 327 TPI?
.. Sounds like need to grab some TPI 350" injectors from the recycle yard... a Jegs 200102 (204/214) or 200103 (214/224) hydraulic flat cam/lifters kit ($89.95) would work well... drop down to Z28 level valve springs ($26) if it has too stiff ones... good roller cams also available if it has been converted to roller lifters... like a ZZ3/ZZ4/ZZ385 (208/221) takeout roller cam...
.. If you could measure the current cam's lift we could prolly figure out about what it is... without having to remove it...
.. Biggest problem is prolly lack of proper accessory mounting holes in ends of 327" heads...
Old Dec 26, 2011 | 03:50 PM
Car: GTA
Re: 327 TPI?
It won't be in a 3rd gen so I would just keep the accessories it currently has, on there.
I think a TPI327 1968 C10 would make a nice tow rig for my GTA.
Old Dec 26, 2011 | 03:54 PM
BuzzLOL's Avatar
Transmission: Many
Axle/Gears: Many
Re: 327 TPI?
.. I would be thinking my GTA would make a nice tow rig for a C10 pickup... or leave the pickup at home..
stalkier
Dec 6, 2015 11:25 PM
Mickeyruder
Sep 2, 2015 02:45 PM
hayesaw0210
Aug 23, 2015 11:15 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
