NEED HELP ASAP! 1987 TRANS AM 305TPI
Old Jan 7, 2012 | 12:38 PM
Pleasehelpme's Avatar
My trans am wont start. Flat out. Tried everything. The timing light is getting a spark, i timed it earlier today, the spark plugs were wet fouled so i replaced 3 and pulled one to see if it sparked and it did. Not starting with starter fluid. What now. Its getting a spark but could it be ignition module still? Someone please respond ASAP
Old Jan 7, 2012 | 07:18 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: NEED HELP ASAP! 1987 TRANS AM 305TPI
when you set the timing, did you do this running? how did you go about setting the timing?
Old Jan 8, 2012 | 02:23 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Pleasehelpme
NEED HELP ASAP! 1987 TRANS AM 305TPI.
https://www.thirdgen.org/forums/tech...-trans-am.html
Should only ask a question about a problem in one place.
Just gets confusing when 2 different groups of guys are trying to help you out
BlueIroc-Z
Jun 9, 2019 03:22 AM
beachrodder
Aug 25, 2015 08:05 AM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
jahblah
Aug 12, 2015 05:54 PM
