another no start
Old Jan 11, 2012 | 10:33 PM
921LE's Avatar
another no start
hello all. 92 camaro tpi 305, t5. Engine only runs on starting fluid. Here is where I am. Getting ready to hand down car to my son. car has sat for 7 maybe 8 years. this is what I have done
1. new cap, rotor, plugs, wires, msd coil
2. new fuel pump, sock, filter, submersable hose in place of pulsator.
3. new fp reg and stainless braided fuel hoses.
4. cleaned fuel rail, all new o-rings, had injectors cleaned flowed and new baskets installed, all are 16 to 16.4 ohm.
5. Replaced all weather pack connectors due to heat age etc.
6. fuel pressure while cranking is 38 psi, set tps to 540mv dead nuts, all injector plugs fire noid light, has hot spark at plugs.
7. all new rubber hoses, vacuum lines, plenum, tb gaskets etc
8. fuel pump does not prime with koeo, but runs with cranking oil psi
9. No codes only 12 when i jump aldl.
10. timing has not been adjusted, and runs well on starting fluid.
What am I missing? thanks and sorry so long winded, wanted to be clear. Car ran great when I parked it.
Old Jan 12, 2012 | 03:51 PM
T/A's Avatar
T/A
Car: 1990 T/A w/WS6
Engine: 5.7L V8 TPI
Axle/Gears: 3.23 w/ posi
Re: another no start
I heard from some where that a fuel filter can be a problem, it was in my car which sat for almost 10 years.
Old Jan 12, 2012 | 04:13 PM
921LE's Avatar
Thanks, I have already replaced the in tank strainer, and in line filter.
Old Jan 12, 2012 | 04:24 PM
92firebird 305's Avatar
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
can a l98 handle a lt4 cam ?
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
