TPI injector identification F2LE-B2A
Old Jan 12, 2012 | 01:39 PM
steves41willys's Avatar
Trying to ID. injectors? Any help would be great thanks
Old Jan 12, 2012 | 01:44 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI injector identification F2LE-B2A
Ford Motorsport / Denso 24# injectors - part number F2LE-B2A
http://users.erols.com/srweiss/tableifc.htm#DELPHI
Old Jan 13, 2012 | 10:03 AM
Thanks These are in a 350 TPI motor I just got and am trying to get installed in a 70 blazer. Proving to be some what of a challange so far. It does have aftermarket high flow heads so the larger injectors will prouably be a good thing. Will prouably need to get a new chip made I guess. Again thanks for reply
Old Jan 13, 2012 | 10:52 AM
Engine: Lb9
Transmission: M20
If the injectors are a little on the large size than you can lower the fuel pressure with a adjustable fuel pressure regulator. You might want to try 38 psi or so before you start adjusting pw. did you ever block your egr valve ?
http://www.megamanual.com/v22manual/minj.htm#size
Old Jan 14, 2012 | 12:04 AM
Thanks No I haven't blocked the EGR. I think I'm going to hook up vacum to it And see if it works. Haven't tried firing it yet. Still a couple weeks away I think. Still trying to figure out all the wireing and have to get the ecm reprogramed.
Steve78LT
Feb 24, 2016 12:15 AM
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
Brcharrelson
Aug 26, 2015 07:47 PM
Sanjay
Aug 12, 2015 03:41 PM
