One of a kind maf problem
I recently bought this 86 Iroc with 5.0 tpi. Previous owner had wired in new maf, burnoff, and fuel relays with new harness's. I put new fuel pump and injectors and gave it a tuneup, also put new maf on as I was getting code 33. Then realized there was a short as it ran the battery dead overnight. When I connect battery cable, the burnoff relay clicks and continues to draw 12 volts. If I disconnect maf sensor, stops current draw. Have checked the grounds with meter, even disconnected ecm to rule that out. All this with the key off. I cannot find anyone with this problem and could use some help with this one, as I have ohmed all wires on circuit and am stumped. PLEASE, Anyone, help.
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
Re: One of a kind maf problem
I bet the wiring for the relay is mixed up. The previous owner may have switched the trigger wire and 12V+ wire for the relay. You will need to decide which is the trigger wire for that relay and trace it, my bet is it is connected to a 12V+ source instead of a switch.
Good luck.
Good luck.
Thanks for the reply, that put me in the right direction. They had the harness wired to right colors, but had to repin the connector. Would have thought a new relay harness would havened have been wired correct for the relay. That's what I get for thinking.
