Tpi 305 removal
Old Jan 23, 2012 | 09:58 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Tpi 305 removal
Ok so in the process of removing a 305 tpi outta a 86 trans am an I was wondering if I can leave all the emission bologna on the motor when removing it I have another 305 from a 90 1500 chevy truck so far I got the tpi manifold, rail an runners on. Also so far I got the bottom an top rad hose off starter wires off, main ground, injector harness disconnecting, tps wiring, iac wire, wondering if I'm missing anything else to remove before actually taking the motor out
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
