Unplugged FP relay, now dead pump.
Old Jan 22, 2012 | 09:59 PM
85IROCzzz's Avatar
Car: 91 Z28
So I was about to change my fuel filter and to bleed off the pressure in the lines I unplugged the fuel pump relay so it would stop the pump. The car died obviously and then I plugged the relay back in. Then I changed the filter and when I turned the key forward to prime the pump I heard nothing. I did it several more times and still no pump turning on. I could however still hear the relay clicking. So somehow I've lost power to my pump...? I checked the fuse in the little holder near the battery and it's fine.
Any suggestions?
Old Jan 22, 2012 | 10:13 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Unplugged FP relay, now dead pump.
Put 12V to pin G of the ALDL plug ( with relay in place ) to see if the pump runs
If not , a problem with pump
Remove relay ,Check for 12V (Org wire ) at relay connector (key off )
if no power , fusible link has likely blown
If power @ relay ,jumper that wire to grey wire and see if pump runs.
If so ,relay is faulty
See
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
Old Jan 22, 2012 | 10:26 PM
85IROCzzz's Avatar
Car: 91 Z28
Ok, which pin is G on the ALDL plug and what is the best way to go about running 12v to it...a wire from the positive side of the battery?
Old Jan 22, 2012 | 10:34 PM
85IROCzzz's Avatar
Car: 91 Z28
I feel like I should also mention that I have already gone out and gotten a new pump and swapped it in (PO hackjob access door) and the new pump does not seem to do anything as well.
I have also tried switching the 3 relays around to see if any of the others worked, and still nothing.
Old Jan 23, 2012 | 12:56 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
But have you checked to see
if you have power from batt at the relay connector as I outlined above?
Jumper the connector to confirm wiring to pump is sound ?
Process of confirm and eliminate until you narrow down the problem
Old Jan 23, 2012 | 12:05 PM
85IROCzzz's Avatar
Car: 91 Z28
Ok so I have 12V at the orange wire at the relay, and when I jump orange to grey I can hear the pump run! So it's a faulty relay? Even though I can still hear it clicking?
Old Jan 23, 2012 | 12:37 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Either that or a faulty connector.
Old Jan 23, 2012 | 01:08 PM
85IROCzzz's Avatar
Car: 91 Z28
Would it be a bad idea to keep that jumper in and drive the car up the road to the parts place to get a new relay?
Old Jan 23, 2012 | 03:16 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Your missing the point,switching the relay isnt solving the problem.The connector the relay plugs into is where your having issues.Fix the connector or cut the connector off and crimp all new spade terminals on each wire and plug them onto the relay.Just be sure to write down where each wire goes to the relay first.
Or do a hot wire fuel pump relay upgrade like racetronix etc when you put in a real fuel pump like the wahlbro 255 and not have to worry about fuel wiring again.
Old Jan 23, 2012 | 05:48 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Separate to the connection problem the others are outlining above
A relay has 2 separate circuits; one that operates the relay and the one that is switched on;
it is quite possibly for the relay to close correctly ( the clicking part )
but no power to pass through because of bad/ worn contacts
Old Jan 23, 2012 | 07:00 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Make sure you push every wire into the connector as mine tend to back out when I plug the connector into the relay.
Old Jan 24, 2012 | 12:41 AM
85IROCzzz's Avatar
Car: 91 Z28
Got it working I pushed all the wires up into the connector but I feel like there will be a reliability issue in the back of mind my mind all the time while I'm driving so I'm gonna re-do the pigtail still.
BumpaD82
Feb 26, 2016 02:57 PM
skinny z
Oct 5, 2015 06:23 PM
lanceflame44
Sep 25, 2015 12:28 PM
Johnoooooo
Sep 22, 2015 08:55 AM
Roxtar69
Sep 15, 2015 05:24 PM
