Fuel rail identification 0446 HUZ
Old Jan 25, 2012 | 05:43 PM
steves41willys's Avatar
Wanting to install a fuel pressure gauge and need to know what year my fuel rails are. My intake is a 85/86 but not sure about the other parts are . Thanks Steve
Old Jan 25, 2012 | 06:02 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel rail identification 0446 HUZ
There should be a 170XXXXX number on one of the fuel rails for identification
Old Jan 25, 2012 | 06:03 PM
Engine: Lb9
Transmission: M20
not sure how you are adapting your pressure gauge but the schrader valve fitting is an -4
Old Jan 25, 2012 | 06:09 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Why?
The thread on the schraeder valve where you install the gauge
is the same -4 AN on all TPI (inc Vette)
Easiest to install one of these -4AN gauge adapters (requires -4 cap to seal open end)
Russell #670290 or similar
R/R without removing the plenum ( unlike the 90 degree adapters )
and mounts any gauge with 1/8" NPT at right angles
Old Jan 25, 2012 | 09:10 PM
I was looking in the street and performance book and they list one[fuel pressure gauge] for a 85/89 and another for 90/92. It looks like it mounts on the schraeder valve so I thought maybe there were different size for the different years. Thanks again Steve
Old Jan 25, 2012 | 09:12 PM
Thanks I will go up to the shop and see if I can find any more # anywhere. Thanks Steve
Old Jan 25, 2012 | 09:13 PM
Engine: Lb9
Transmission: M20
I think on the 90-92 map there was a optional bracket used to make the gauge mounting more stable.
Old Jan 25, 2012 | 09:22 PM
Engine: Lb9
Transmission: M20
http://www.ebay.com/itm/Accel-DFI-74...d#ht_500wt_951
Old Jan 25, 2012 | 09:24 PM
That sounds likely. I might call S&P and ask if there is any thing else with there mounting. Have you or anyone else you know ever tried one of the air foils they make for the throttle bodies. Was thinking about one of those also .
Old Jan 25, 2012 | 09:26 PM
Engine: Lb9
Transmission: M20
I would go with one of these, price is right.
http://www.ebay.com/itm/AIR-FOIL-THR...#ht_2730wt_936
Old Jan 25, 2012 | 09:31 PM
Both of those look good and both cheaper than S&P Thanks again Steve
Old Jan 26, 2012 | 12:36 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Same question asked every week.
https://www.thirdgen.org/forums/post...418-post9.html
https://www.thirdgen.org/forums/post...067-post5.html
https://www.thirdgen.org/forums/post...08-post13.html
http://www.corvetteforum.net/c3/zwed.../dynotests.htm
Andrew6.688
Dec 13, 2015 10:59 AM
stalkier
Dec 6, 2015 11:25 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
