TPI Plenum
Old Jan 25, 2012 | 07:52 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
TPI Plenum
Does anyone have a diagram of what everything in the plenum is and / or goes to? like vacuum lines and sensors?
Old Jan 25, 2012 | 08:04 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: TPI Plenum
passenger side should have 3 ports(nipples)near the distributor, rear one is for heater vacuum,middle should be map sensor and front one is fuel pressure. Honestly,it doesnt matter which ones u use for what,so long as the hose fits. On the opposite side (rear of plenum) is for brake booster. Under the plenum is the AIT sensor (air intake temp sensor).Also MAP sensor bolts on the plunum in its upright position back by the 3 ports. It should have a small "L" shape hose
Old Jan 25, 2012 | 08:20 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI Plenum
https://www.thirdgen.org/forums/tech...iagrams-i.html
post 18
MantyZ28
16
Dec 21, 2015 11:02 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
355tpipickup
Aug 22, 2015 06:06 PM
Sanjay
Aug 12, 2015 03:41 PM
