Engine Harness Routing
Old Jan 30, 2012 | 07:45 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Does anyone have a good clean pic of their TPI engine harness. Im trying to plan out the routing.
Main question is does the harness route under the plenum at all? Im swapping in a motor not sure wheather is makes sense to put the plenum on in the car or before i drop it into the car.
Old Jan 30, 2012 | 07:50 PM
BrownBullet83Z's Avatar
Car: '83 Camaro Z28
Engine: "Just a little something"
Axle/Gears: 3:73
Re: Engine Harness Routing
There is the MAT and EGR sensors that run under as well as HVAC vacuum harness' but the MAT and EGR have connectors also BEHIND the plenum so you dont have to pull it (or should anyway)
Jorlain
Aug 24, 2022 05:11 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
