fuel line replacement
hi, im putting a tpi engine in my 86 t/a, with walbro in line pump,i have to do new fuel lines,,can i use some steel fuel line all the way like factory,but use fuel injection rubber hose with fuel injection clamps for rear(pump/filter/tank) connections and also for the front portion of flex hose? or does it have to be like the service manual claims that i HAVE TO use all gm replacement fittings and hoses.
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: fuel line replacement
Your plan should work fine. For safety, I Double-Clamped all my hose connections, but that is probably overkill.
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
