Injector replacement parts list
Old Feb 6, 2012 | 08:36 PM
libolt's Avatar
Car: 1991 Trans Am
Hi,
I did the resistance test on my injectors and at least one of them is bad. So I'm going to be ordering a set of replacements soon and want to make sure I take care of everything while I have it disassembled. Here's my current parts list:
- Injectors (Bosch III 19lbs)
- Adjustable Fuel Pressure regulator
- Felpro plenum gasket kit
- One replacement Injector connector and wire (plastic clip is broken)
Is there anything that I'm missing or should replace while I'm at it? This is the first time i've done something this complex with the engine.
Thanks,
Mike
Old Feb 6, 2012 | 08:46 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Injector replacement parts list
Change the fuel filter first and run the engine before you disassemble. Might as well run any residual dirt through the old injectors instead of the new ones.
Make sure you lube the injector "O" rings when you reassemble. I think your parts list is complete, it's not really a very big job. Just go slow and dont force anything. If you have it right, the parts will fall together very nicely.
Old Feb 6, 2012 | 08:50 PM
joeld's Avatar
Car: 1986 Firebird, 1989 Vette, 1995 GP
you will need a fuel rail O-ring kit.
Joel
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
