TPI in a 74 monte carlo
Car: 1986 Monte SS
Engine: 383 Stroker
Transmission: 4 Speed Saginaw
Axle/Gears: 3:73 Eaton Locker
Hey guys, new to the forum.
I'm putting a 1986 TPI in my wifes 74 Monte Carlo, where can I go to get a custom burned chip, I need one with the egr, 9th injector, vss, tcc, etc...removed.
I want to go maf, I have everything as far as mechanics go, just need to find the right path to the chip.
A little info on my set up: 1986 tpi from a firebird vin: f (305), full harness with all sensors, computer, ect.... going on a 400 sbc stock everything, 225 BHP, thanks for the help guy's!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI in a 74 monte carlo
Welcome to the forum, do you currently have a memcal from the 86 1227165 ecm ?
Car: 1986 Monte SS
Engine: 383 Stroker
yes I do, But not right in front of me.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Engine: Lb9
Transmission: M20
There is kinda a trade off yes $6e does not use the cold start and adjusts pw for cold start. $6e also has a lean cruse highway mode were $32 does not. 87-88 $32B can be changes to work well with cold start conditions and also contains an additional maf table so the maf tables can be more refined.
Sanjay
Aug 12, 2015 03:41 PM
