TPI Engine Bay Clean-up Vacuum & Smog
Old Dec 11, 2018 | 01:46 AM
  #51
Drew's Avatar
Re: TPI Engine Bay Clean-up Vacuum & Smog
M-F'er. When you meet a stranger in the Alps, he'll fill you in.
Old Dec 11, 2018 | 06:56 AM
  #52
Dusty Dc's Avatar
Hahahahah thats perfect. In 31 years I've never heard that. I just added a new word to my dictionary. Ok back to the business. So that pipe goes to the heads you said and not the cat.?
Old Dec 11, 2018 | 10:05 AM
  #53
Dusty Dc's Avatar
Originally Posted by Drew
Usually the converter is on it's own spur. The one with the Tee is the Melon-Farmer pipe. It goes behind the engine, bolts to both heads, and feeds the driver's manifold. It's a real Melon-Farmer to work around, and remove because it's a one piece steel pipe that is bolted in.
This one is off an 86, thinking 87 until they went to the rubber version were about the same aside from minor changes. This one came out with the engine.
May God have mercy on your soul. Amen.
well let me ask you this drew. Since I'm removing all emissions and smog etc. If I cant get to the back of the head can i cut it off and plug it?
Old Dec 11, 2018 | 01:29 PM
  #54
Drew's Avatar
You could, it's just a tube from one manifold to the other. Personally I'd do my best to remove it in one piece. At some point, parts like that will carry an insane resale value.
Old Dec 11, 2018 | 02:16 PM
  #55
Dusty Dc's Avatar
Yea but theres mo way to get my hand back there
Old Dec 11, 2018 | 03:13 PM
  #56
Drew's Avatar
Yep, it sucks regardless what you do. I'm not entirely sure, but all the block grounds might be on the same stud in the head that the tube is bolted to... Makes it a real MF'r to get anything apart. I'd expect even cutting the tube would be a pain with as tight as everything is back there. Could always just cap the ends so it looks clean.
The AIR injection piping is one of the things that GM really perfected as time went on. The earlier cars have valves and hoses running everywhere. Then they went to the hard pipes around the back of the engine, and finally went to a rubber hose in the later years. Nice thing about the rubber hose is it practically just pulls out once it's unhooked from the valves. Also since it's flexible, you can just tuck it out of the way.
Old Dec 11, 2018 | 03:14 PM
  #57
Dusty Dc's Avatar
that's what I was going to do is cut it and the cap it off nice and clean like
Old Dec 11, 2018 | 03:55 PM
  #58
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Melon-farmer, lol. I never heard that before
I had an 88 GTA and it had the same hard tube around the back of the engine. Pretty sure the 91 TA I have also has the hard tube around the back
Old Dec 11, 2018 | 03:56 PM
  #59
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
My 91 z28 had the rubber tube
Old Dec 11, 2018 | 04:17 PM
  #60
Dusty Dc's Avatar
I tried reaching back there to no avail so I'll just cute it and cap it and call it a day that way I can get started on running the coolant bypass line. This is a damn project boyos lol
Old Dec 11, 2018 | 04:22 PM
  #61
Engine: Lb9
Transmission: M20
Tb bypass ?
Dayco 87662 makes a good tb bypass hose.
Old Dec 11, 2018 | 04:24 PM
  #62
Dusty Dc's Avatar
Yea TB bypass. I'll look into that. Parts store didnt have anything so may have to look online
Old Dec 11, 2018 | 04:29 PM
  #63
Engine: Lb9
Transmission: M20
Old Dec 11, 2018 | 04:34 PM
  #64
Engine: Lb9
Transmission: M20
Old Dec 11, 2018 | 04:54 PM
  #65
Dusty Dc's Avatar
Yea asvance auto has em. Itll work since I'm bypassing the heater valve also
Old Dec 11, 2018 | 04:56 PM
  #66
Engine: Lb9
Transmission: M20
You can get a barbed hose coupler at Home Depot.
Old Dec 11, 2018 | 05:02 PM
  #67
Engine: Lb9
Transmission: M20
I think it’s 3/4 or could be 5/8
Old Dec 11, 2018 | 05:07 PM
  #68
Dusty Dc's Avatar
Already got em. Parts store local carries the stuff for me for my shop
Old Dec 11, 2018 | 08:03 PM
  #69
BizJetTech's Avatar
Unless you have a DD and live in a cold climate, why not just bypass the heater core and eliminate it?
It's bound to start leaking (if it already hasn't) anyway
Old Dec 12, 2018 | 04:46 AM
  #70
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
You should always keep the heater working. You will regret it.
Old Dec 12, 2018 | 06:25 AM
  #71
Dusty Dc's Avatar
I never cut out heat. Even on my track card it's still there. Plus I do live in a moderately cold climate half the year.
Old Dec 12, 2018 | 06:43 AM
  #72
BizJetTech's Avatar
why is that ??....in the 35 plus years I've been messing with these cars I have yet to regret it.....
Old Dec 12, 2018 | 02:48 PM
  #73
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
You live in Florida some houses don't even come with heat in them, the rest of us need it to defrost the windshield on occassion
Old Dec 12, 2018 | 03:04 PM
  #74
Dusty Dc's Avatar
Hahahah I spit my drink all over the computer. But it's TRUE. Defrost very much needed up north.
Old Dec 12, 2018 | 03:14 PM
  #75
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Old Dec 12, 2018 | 03:41 PM
  #76
BizJetTech's Avatar
I lived WAY up North most of my life (Wisconsin) and still never had heat in my cars because when the first cold spell
came in I'd stop driving the cars - I'm lucky to put 300 miles a year on these cars, so no need for heat no matter where I live
Old Dec 12, 2018 | 05:55 PM
  #77
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I daily my 92 JY Firebird, so heat is a necessity, currently live in they tyrannical state of New Jersey
Old Dec 12, 2018 | 06:44 PM
  #78
Dusty Dc's Avatar
I dont fsmily my 87 quite yet bc I've been putting all new stuff on it. But I probably wont bc ot only has 17k miles on it and I live in PA.
Old Dec 20, 2018 | 01:39 PM
  #79
Dusty Dc's Avatar
Let me pose you chaps one more question. Exhaust Manifold removal. When taking them off the exhaust flange/down pipe.. easier from up top or on the bottom?
Old Dec 20, 2018 | 10:34 PM
  #80
Drew's Avatar
Come up from underneath with a LONG extension and a deep well socket. Make sure the extension is long enough you can get angry on the breaker bar from under the car without smashing your fingers. Be ready, the studs like to snap off, but if you're not putting the manifolds back it won't matter. Sometimes the nuts will stick to the studs and the studs just unscrew from the manifold. Either way, getting em out ain't bad.
Old Dec 20, 2018 | 10:42 PM
  #81
Dusty Dc's Avatar
Yep putting new ones on. So no worries.
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
Sanjay
Aug 12, 2015 03:41 PM
