HELP! Failed Smog High NOX
Old Feb 20, 2012 | 05:19 PM
camarocasanova's Avatar
I finally took it in to see just what I am dealing with as far as smog goes.
Car is 1989 305 TPI auto/2.73
This is a KALIFORNIA smog
It is completely stock except magnaflow in the back.
I installed new plugs, wires, cap, rotor, pcv, fuel filter, oxygen sensor, a bunch of new vacuum line, new coolant sensor (computer) new air filters, new oil and filter, cleaned mass air sensor, cleaned throttle body blades. Car has new fuel pump, tank, and recently cleaned injectors.
I did not check the egr valve or any of its components other than fixing bad vacuum hoses. I have not seafoamed anything but did run some fuel injector cleaner through it for a few miles.
Ran it for a good 35 miles got it hot, went right in to smog shop.
Passed everything but NOX....So I would love to hear what I need to do next, I am thinking clean egr passages and new egr, and then a catalytic converter if that does not work.
Any thoughts would be appreciated guys.
Old Feb 20, 2012 | 05:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: HELP! Failed Smog High NOX
The two rows are idle and accelerated?
Old Feb 20, 2012 | 06:41 PM
Sorry the two rows are 15 mph and 25 mph tests
Old Feb 21, 2012 | 02:18 PM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
Timing that is advanced too far will cause high NOx's, what is your timing set at?
Old Feb 21, 2012 | 02:52 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
I'd check the EGR valve and look for a plugged hole in the intake where it mounts or maybe a bad gasket. Make sure the hose going to it is in good shape.
Old Feb 21, 2012 | 09:47 PM
timing is set at 5 degrees
I took off the plenum, runners, and egr tonight. All vacuum lines look good no breaks or tore up rubber lines. I believe some carbon in the manifold as I snaked it out. No carbon from runner to egr but from other side I believe clogged.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
racereese
Oct 10, 2015 09:39 PM
327IROC85
Sep 23, 2015 12:11 AM
reactor60
Sep 22, 2015 01:44 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
