Can you use 21lb injectors in 1990 5.7 ?
Old Feb 20, 2012 | 05:33 PM
71nova's Avatar
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
I recently installed 21lb injectors and adjustable fuel pressure regulator in my stock 5.7 1990 IROC. Are there any problems associated with using this size injector and how do you determine where the fuel pressure should be set at for optimum performance.
Old Feb 20, 2012 | 05:39 PM
ahankins32984's Avatar
Car: 1986 Camaro Z28
Engine: 5.0 305 TPI
Axle/Gears: posi 3.73
Re: Can you use 21lb injectors in 1990 5.7 ?
I have a friend on here that owns a 1990 IROC with the 5.7 and he uses the 21lb injectors with absolutely no problems!!!!!
Old Feb 20, 2012 | 06:09 PM
71nova's Avatar
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
Thanks for the input. I've put a couple hundred miles on them and they seem to be working out pretty good. I see a lot of people on here talking about 22lb injectors and I don't really know what the rating means, what the difference is, or what the car came with stock and how it would affect performance. I do not know if the injectors I replaced were original. I believe the injectors I replaced and the fuel rail had the name Rochester on them.
Old Feb 20, 2012 | 06:33 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
iirc, 21 is the stock size for 5.7s (19 for the 305).
Old Feb 21, 2012 | 07:24 PM
southbay08's Avatar
The injectors will be fine. The stock injectors for a 5.7 is 22lb, for a 5.0 it is 19lb @ 43.5psi.
21lb/22lb.....engine will never know the difference.
Old Mar 5, 2012 | 07:03 PM
myzblubyu's Avatar
Car: 1990 Iroc, 1984 Buick Regal
Engine: 5.7, ZZ4 crate w/FIRST injection
Transmission: 700r4, 700r4
Axle/Gears: 3.73, 4.11
I run 24lb injectors and they are great, the factory size was 22lb... You should be fine...
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Jlanz55
Sep 8, 2015 11:28 PM
tgp1990
Sep 4, 2015 06:24 AM
IROCtometal
Sep 2, 2015 02:01 PM
