Where should I adjust my fuel pressure to?
Old Feb 21, 2012 | 05:37 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Pretty close to being done with my swap but not sure where I should set my fuel pressure at, my mods are the following.
Fully rebuilt 1987 L98 converted to Speed Density from a 91
Crane 2032 cam
TPIS Big Mouth Intake
Ported SLP Runner
Ported Plenum
AFPR
MSD Distributor and wires
Hooker 2055 headers and Y pipe
Walker high flow 3" cat
Magnaflow 3" catback
also fuel pressure is adjusted with vacuum line off, correct?
Old Feb 21, 2012 | 06:20 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Where should I adjust my fuel pressure to?
Crane 2032 cam
Ported SLP Runner
Ported Plenum
AFPR
Yes with the line off and plugged. Set it to 43.5 psi and see how it runs. That is GM stock pressure for the 22lb injectors
Old Feb 21, 2012 | 06:21 PM
ninetyone's Avatar
Axle/Gears: 3:42
With your mods,your car might want a little more pressure/fuel though. You can try raising it slightly ,a pound makes a difference you can tell,but i wouldn't go past 50 psi
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
Kaweh
Aug 9, 2015 02:54 PM
