fuel pressure gauge
Old Feb 26, 2012 | 05:14 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
fuel pressure gauge
eventually ill pick up an adjustable fuel pressure regulator but for now im debating with going with a hypertech gauge (easy on and off), or a more permanent mount using a jegs 60 psi gauge and some AN fittings.
which way seems better by opinion?
Old Feb 26, 2012 | 09:21 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: fuel pressure gauge
I would go with a gauge u can take on and off just to check the pressure when needed,safer option IMO.
Old Feb 26, 2012 | 09:23 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
+1 on that, you will be able to use it on other cars also. Oreilly's has them for about $30 i think.
Old Feb 26, 2012 | 10:31 PM
ninetyone's Avatar
Axle/Gears: 3:42
make sure you get one that has the proper size fitting for your GM. I dont remember if ours is 1/8,1/4 etc
Old Feb 26, 2012 | 10:42 PM
Brando5641's Avatar
They come with adaptors to fit a lot of diff. cars.
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Kaweh
Aug 9, 2015 02:54 PM
