fire by distributor
Old Feb 29, 2012 | 01:33 PM
85whtz28's Avatar
Car: 1985 Camaro Z28
fire by distributor
just like it sounds, had a fire right by the distributor. My question is will an 1986 harness work in 1985 tpi? I am more concerned with the ECM and MAF.
Old Feb 29, 2012 | 03:08 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: fire by distributor
85 and 86 should be the same as I believe 87 was the first year for the small cap hei.
Old Mar 1, 2012 | 10:39 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
the ecm connector will need to be repinned for the 165 to the 870. if you can get a maf and 1227165 ecm for a 86-89 it would be a great upgrade.
Old Mar 1, 2012 | 11:06 AM
85whtz28's Avatar
what about the two harness' for the burnoff and relay by the ecm? do I need those also?
Old Mar 1, 2012 | 11:29 AM
Engine: Lb9
Transmission: M20
for the upgrade you mean ? http://www.eecis.udel.edu/~davis/z28/ecm_swap/
Old Mar 7, 2012 | 01:55 PM
85whtz28's Avatar
So I decided to go ahead and do the swap to the 1227165 ecm. I have a list of compatible cars that use the same ecm. Can I use my prom out of my 85 ecm? I dont see a difference in part numbers. The ecm I found is out of a 1987 Sonoma 2.5l
Old Mar 7, 2012 | 02:40 PM
Engine: Lb9
Transmission: M20
you will need a memcal for the swap look for a bcc from 86-87 camaro those will not have vats.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Damon
Sep 26, 2015 04:29 PM
