fuel pressure gauge
Old Mar 4, 2012 | 01:49 PM
dez58pop's Avatar
fuel pressure gauge
hi can anybody help me and tell me what fittings i need please to make a fuel pressure gauge ,does the valve in the injector rail need to come out and a male fittings screws in or a female threads on top of the valve ,just the middle of the valve needs to be pushed in to release fuel ,like a valve in a tyre to relase air ,also doles the gauge need to be liquid filled ,just i have a 100psi gauge with a 1/4 npt fitting thats not liquid filled, thanks for your help
Old Mar 4, 2012 | 01:52 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: fuel pressure gauge
you should see the male threads on the fuel rail. tap in there. kinda screws on like a kids bicycle air pump.
Old Mar 4, 2012 | 01:58 PM
dez58pop's Avatar
yep i know where that is so does all that valve come out ,and put a 1/8 npt male thread in its place and build off that ?
Old Mar 4, 2012 | 02:04 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
no. i always just screwed the hose/fitting onto the valve. it will depress the needle and allow fuel pressure once its tightened properly. im not sure on the thread sizes. just use the correct one. ive used a cheap one fron harbor freight tools before. worked ok.
Old Mar 4, 2012 | 02:06 PM
dez58pop's Avatar
ok thanks matey
Old Mar 4, 2012 | 02:08 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i dont think id want a high pressure liquid filled fuel pressure gauge if thats what your trying to do? for a reading or diagnosis,...sure. not permanent.
Old Mar 4, 2012 | 02:38 PM
Guest
Guest
Posts: n/a
-tire value tool to remove the spring core-
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Kaweh
Aug 9, 2015 02:54 PM
