89 L98 tries to start but won't
Old Mar 16, 2012 | 11:42 AM
al1270's Avatar
Car: 1989 Iroc
Engine: 383
Axle/Gears: 4th gen posi 3.73
I have been reading a ton of old posts trying to figure this out. I have tested with postive results:
injector restistance
coil
spark
ignition module
coil pick up
Engine turns, no codes tries to fire once in a while if you hold the key. Security light is not on (previous owner also said he had the vats program disabled when he had a custom chip burned).
Plugs, wires, cap, rotor, throttle body, tps is new. Fuel pump comes on. If you crank it for awhile you can smell gas.
I want to get a noid light but not sure whch one to test injector pulse. I'm stumped because it will try and start.
Here is a little more info on the car I bought it last july.
https://www.thirdgen.org/forums/mid-...no-tuning.html
https://www.thirdgen.org/forums/atta...tune-final.jpg
Old Mar 16, 2012 | 09:01 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 89 L98 tries to start but won't
Simple
Have you pulled some plugs out; are they wet or dry ??????
Wet ; no spark
Dry ; no fuel
Need to establish that in order to know what direction to proceed in investigations
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
justin57
Aug 20, 2015 07:05 PM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
