Help! 355 Tpi starting issues
Old Mar 20, 2012 | 01:13 AM
Z28NZ's Avatar
Car: 85 Z28
Engine: 355 Vortec TPI
Axle/Gears: Stock
Long story short.Car was rear ended and is in the panel shop, driven there no issues, they rang, car is done but died and wont start so off I go to take a look and yes it is as they say. My findings are- battery is good. connections seem tight. I turn the key on, fuel pump runs and stops as per normal and then twist key to start and nothing except the water temp needle goes straight up to top of guage and the radio cuts out. No check engine lights prior or during this. Its like the transmission interlock switch is jammed on, tried shifting position of gear shift, no start anywhere. Left key on and tried shorting the two starter terminals to wind over, just a spark but no engagement of solenoid. Currently I am stumped and not sure what to look at next, never had an issue like this before, Help!
Old Mar 20, 2012 | 08:55 PM
utilityguy2's Avatar
Re: Help! 355 Tpi starting issues
Dead battery?
Old Mar 20, 2012 | 11:57 PM
Z28NZ's Avatar
Car: 85 Z28
Axle/Gears: Stock
Originally Posted by utilityguy2
Dead battery?
No, Battery has tested fine
Old Mar 21, 2012 | 12:40 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
That would indicate a problem with the starter.
Should at least hear the solenoid click (even if battery was too flat to spin starter over ).
Did you use the correct small terminal on solenoid ; the one with purple wire on it ,
jumpered to the main batt terminal?
Old Mar 21, 2012 | 10:36 AM
No check engine lights with key on is a clue. Have you checked all of the fuses? And don't forget the fusible link near the battery That powers the ignition switch. Even if that is blown, jumping the starter should still engage it if the battery is good or at least hear it click as VetteOz said.
Old Mar 22, 2012 | 11:24 PM
Z28NZ's Avatar
Car: 85 Z28
Axle/Gears: Stock
Yep, starter shot, confirmed by an auto sparky. Was the original starter off the original 305 so 27 years not a bad run and I guess the high comp 355 now in it was too much for it. Hitachi mini starter now going to be fitted. Thankyou all for your help
Cheers Simon
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
86Base
Aug 8, 2015 01:34 PM
