Rear End Help Please!!!
Old Mar 22, 2012 | 01:28 AM
twest2k2's Avatar
Car: 87 Camaro IROC-Z 5.7 TPI
Engine: 350 aka 5.7L Tuned Port Injection
Transmission: 700-R4
Axle/Gears: 3.27 posi
my Camaro came with a 9 bolt borg warner 3.27. It is now over 25 years old, leaking oil, Definitely due for a rebuild. Should I keep it or sell it? My brother has a 10 bolt with 3.73 gears that just came out of his 87 Iroc in good working order. Should I swap them? would I be better off, worse, same?
I am doing a lot of mechanical upgrades in the near future, eventually getting a moser but those are very expensive as you all know. i currently have rear disc brakes if that matters.
Old Mar 22, 2012 | 01:30 AM
twest2k2's Avatar
Re: Rear End Help Please!!!
btw , by swap i mean the whole thing, not trying to mix and match
Old Mar 22, 2012 | 07:22 AM
capj66's Avatar
Car: 1987 IROC
Axle/Gears: Borg Warner 9-Bolt Disc 2.77
I have an 87 with a Borg Warner in it. They are great, strong rear ends but the parts are harder to come by these days. If you have a good 10-bolt available for the right price I would just swap them out. It is a straight swap and would probably take you all of 3 hours to do. A 10-bolt is more than adequate for a daily driver that you get on every once in awhile and have a little fun. 3.73 gears on the auto may be a little steep in my opinion, I would swap the gears to 3.23 or 3.42....
Old Mar 22, 2012 | 10:26 AM
twest2k2's Avatar
Thank you for the info
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
