setting idle speed adjustment
Car: 1989 camaro iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
has anybody set there idle air control and idle speed with the article that on this web site and if so do you put the car in drive our leave in park to set the idle speed if so did it work
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: setting idle speed adjustment
You do it in gear with a auto because the computer changes the idle revs when the car is put into gear
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
in park jumper the aldl pin a to b and set the min idles speed adjustment to 450rpm. the p/n switch does do a adder to the idle speed. do not do anything with the car in gear.
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
so set the idle in park and when it is in the close loop is this right
. thanks for you help
